motor mount bolts
Why can I not figure this out?? What bolts do I need for my motor mounts?
What bolts from mount to engine block What bolts from mount to chassis/frame On Jegs and summit are they just using the wrong picture for the motor mount to chassis/frame? The picture simply shows a bolt and washer with no nut. I don't see how it holds? |
The motor mounts are two pieces.
The block is threaded so that half doesn't need nuts. The chassis half is mounted with a short bolt/nut combo. The two halves are connected with a long bolt/nut combo about 5 inches long. |
