Fluid leaking from under my dash on the Drivers side
I have fluid (looks like brake fluid) leaking from a part under my dash on the drivers side, I'm not sure what it is looks mechanical but also has wires running into it. I can't seem to find anything on line that says what it is.
thanks
thanks
brake fluid is reasonable...the master cylinder is right there...open the hood pop the lid off the brake MC and see how much fluid is there...If it is brake fluid the MC should be replaced yesterday.
other thoughts are leaking cowl, quite normal and windshield washer fluid. But most likely brake fluid. That stuff will eat your paint so clean it up and get it fixed before the lack of brakes eats your pony. 65 had a single master cylinder so get it fixed doubly quick.
