66 V8 Auto Tranmission Kickdonw Issue
Old 07-05-2017, 09:36 PM
LAWRIMORE66MUSTANG
LAWRIMORE66MUSTANG's Avatar
Question 66 V8 Auto Tranmission Kickdonw Issue
I have a 1966 Mustang V8, Edelbrock 4v Carb, Edelbrock Intake. Nothing really performance enhancing, Automatic C4. The issue I am having is that it will shift normally for a while but then all of a sudden the car will shift from 3 to 2nd without me touching the accelerator. This happens at around 40mph. I can completely release the pedal and it will then shift back to 3rd again only to downshift a few seconds later. I recently purchased the vehicle and do not know what has been done to it. I can see the kickdown cable and it does not seem to be overly tight or loose.
What else can I check to see what may be the issue.
LAWRIMORE66MUSTANG is offline
Old 07-05-2017, 09:53 PM
Gun Jam
Moderator
Gun Jam's Avatar
you could check into the modulator. Read up on how it functions. It's likley a possible issue.
Gun Jam is offline
Old 07-05-2017, 10:36 PM
Starfury
Starfury's Avatar
Sounds like it could easily be a modulator problem.
Keep in mind that there are several modulators available, each identified by colored ring(s) around the outside of the housing.
Starfury is offline
Old 07-06-2017, 06:33 AM
LAWRIMORE66MUSTANG
Are they pretty easy to replace?
Old 07-06-2017, 06:54 AM
LAWRIMORE66MUSTANG
I looked it up and will replace that first. Seems like the easiest thing to do. Hopefully that is all it is. I will also check the vacuum lines for any types of leaks.
