Water and shaker hood - MustangForums.com
Old 08-09-2018, 11:54 PM
newmex999
Default Water and shaker hood
Here's what I hope is a silly question? What prevents water entering the hood scoop from filling the lower portion of the shaker assembly (where the air cleaner sits) and entering the carb? I do not have a snorkel assembly and a plate is covering the area where snorkel was.
newmex999 is offline
Old 08-10-2018, 02:29 AM
08'MustangDude
The way manufacturers get around the problem of the wet is usually through creating
a dead zone where the water will fall out of suspension, then the water is collected
and allowed to drain through a tube out onto the ground. If the filter gets a little wet,
there's no real issue. A little water getting in through the intake is not going to create
an issue. Your engine can ingest and "burn" (used tongue-in-cheek) a little water
without causing an issue.
Some people will install more drain hoses into their Shaker, but there should be at least one
already present.
The 1970-1971 originals shakers had two manually-controlled flaps that could be closed by
a pull-cable mounted under the dash. Newer ones have drain holes, or a drain hole.
08'MustangDude is offline
Old 08-10-2018, 08:23 PM
barnett468
No they did not.
barnett468 is offline
Old 08-11-2018, 12:54 AM
08'MustangDude
Originally Posted by barnett468 View Post
No they did not.
Prove it. My uncle has owned nothing but Mustangs. Some had shakers, and
I was shown the flaps, and how they work.
Maybe it was dodge... Hmmmm......
Old 08-12-2018, 07:07 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
No flap on a shaker that I remember seeing. The NACA hoods on the 71 / 73 had vacuum operated flaps didn't they?
fastbackford351 is offline
BRENSPEED
12-15-2012 12:56 AM
LynnBob Mustang
08-11-2007 06:58 AM
Quick Reply: Water and shaker hood
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
