A/C compressor - York/Tecumseh style '67
Old 12-14-2018, 09:53 PM
OldRustyWrench52
OldRustyWrench52's Avatar
Question A/C compressor - York/Tecumseh style '67
Need to know dimensions of the case across the lower four mounting holes, front to back. I'm preparing to start this engine on a test stand, so need to have the water pump bolts tight, but would like to have all brackets in place so when I'm ready for the compressor, I can just drop it in place. The vehicle is a basket case I'm helping a friend put together. The brackets are there, but the compressor is missing. Anyone know what this measurement is? I'm guessing it's around 4 5/8".
OldRustyWrench52 is offline
Old 12-15-2018, 09:28 AM
barnett468
barnett468's Avatar
ok, i'm confused. you do not need the dimensions because the holes in the bracket the compressor mounts on are obviously the same dimensions as the holes in the compressor. The bracket in your photo is not correct for an early mustang compressor. It looks like one for rotary compressor.
barnett468 is offline
Old 12-15-2018, 06:44 PM
OldRustyWrench52
To barnett468:
I know GM went to 4 cyl rotary compressors when they fazed out the 6 cyl axial compressors a few decades back. Did not know Ford used rotary compressors. Do you have a photo of a Ford rotary? Do you know where I could go to get the dimension I'm looking for? Even with a Ford part # (C3AZ-19703-F) google is no help.
OldRustyWrench52
Old 12-15-2018, 10:17 PM
OldRustyWrench52
To barnett468:
Just remembered GM's 4 cyl A/C compressor was radial, not rotary. Were early Mustang A/C compressors something other than the York/Tecumseh style?
Old 12-16-2018, 10:30 AM
barnett468
barnett468's Avatar
Originally Posted by OldRustyWrench52
To barnett468:
OldRustyWrench52
This is from an 82 mustang. you can google "1984 mustang engine compartment photos" then click "images. change the year you re searching for until you find what you are looking for. I can't tell if this is what you need or not. Another thing you ca do is look at the date code on the block if the engine and brackets all came together originally. This will tell you what year it is from.
Old 12-16-2018, 10:33 AM
barnett468
barnett468's Avatar
To barnett468:
64 thru around 78 mustangs used a york/tecumseh piston type compressor, not a rotary one.
cyp66stang
02-11-2014 08:47 AM
The Pirate
06-13-2010 08:11 PM
rmodel65
4 Cylinder NA and Turbo
04-29-2009 01:56 PM
maniac_3_2000
12
07-27-2007 12:59 PM
5.0ttop
03-27-2007 04:11 PM
Quick Reply: A/C compressor - York/Tecumseh style '67
