Automctic transmission c3 1965
Old 12-24-2018, 06:35 AM
Candy M
Default Automctic transmission c3 1965
Hallo i have mustang 1965 with engine 3.3 liter and automatic transmission c3. I was repair transmission (change clutch) .After i tested transmission the car cant go to program D but program R was ok. Please what can be wrong ? Thank you from answer.
Candy M is offline
Old 12-24-2018, 12:48 PM
barnett468
Can you put the shifter in 1st, 2nd, and drive and park positions?
Does it go forward if you put the shifter in 1st or 2nd?
Did a transmission shop rebuild and install the trans?
barnett468 is offline
Old 12-24-2018, 04:58 PM
Candy M
Yes i can put position but i put D or 1st or 2st the car does not go forward as if put N. R mode is okay
Candy M is offline
Old 12-25-2018, 11:12 AM
barnett468
ok, if your transmission has enough fluid, AND, the torque converter is installed correctly, AND the shift linkage is tight so it is not slipping on the external shift rod, then the problem is inside the transmission itself . If the problem is inside the transmission, it means the shop that built it did not do it correctly. Hopefully they gave you some type of warranty/guarantee.
Old 12-25-2018, 02:46 PM
Candy M
I thing the outside transmission is good . I repair transmission in home but I dont now what is dont instal uncorectly . In front of rebuild the speed go okay . What uncoretly inside ?
Candy M is offline
Old 12-25-2018, 07:36 PM
barnett468
i don't know exactly what part inside the trans can cause this. it could be many things, but the easiest thing to check is the valve body and make sure all the check ***** etc are in the right place and that the pistons move freely and have the right springs etc.
Old 12-26-2018, 06:51 AM
Candy M
Today i tested my transmission like in this video https://youtu.be/ucTqlOHhCxM . And when i test clutch the air dont push the clutch and blow in transmission. Maybe its wrong control the clutch . Please how the control clutch works ?
Candy M is offline
Old 12-26-2018, 12:58 PM
barnett468
I don't know much about auto transmissions. You might need to find someone near to you or email bad shoe productions or try a transmission forum etc.
cmdavis
02-15-2008 01:06 PM
bradleybrownstein
Classic Mustang Classifieds
08-28-2007 06:57 PM
MustangPilot65
08-25-2007 06:15 PM
bradleybrownstein
Want To Buy Ads
05-31-2007 01:09 AM
gregp1962
09-05-2006 04:37 PM
Quick Reply: Automctic transmission c3 1965
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
