Radiator with a slow leak - Repair or Replace?
Old 02-17-2019, 04:59 PM
Scott40talbot
Default Radiator with a slow leak - Repair or Replace?
Somewhat of a simple question. I have a slow leak on the upper seam of the radiator. Is there an easy fix, or should I replace it? Thanks
Scott40talbot is offline
Old 02-17-2019, 05:43 PM
Gun Jam
Moderator
Gun Jam's Avatar
Im in the same boat. I found that it kind of stopped leaking after a while. I guess enough crap built up around the leak site that it partly self sealed.
It should be replaced is the obvious answer but in my case its a 500 dollar radiator thats less than 3 years old. I have a digital real time temp gauge with 1/10th degree precision by Aurber instruments with audible warning that comes on when temp is below or above a custom (set by user) range. I daily drive my car and without that audible warning on a precision gauge I would NOT dice roll that engine on a small water leak. because I forget to keep adding water and the change in water level plays hell on the electric fan temp probe causing it to start late and it gets worse as it gets lower.
Gun Jam is offline
Old 02-17-2019, 06:46 PM
Scott40talbot
Thanks Gun Jan, Iwhile i was hoping for a different answer, you right.
Old 02-18-2019, 04:13 AM
08'MustangDude
I had a small pisser leak in the side tank of my former '06 Liberty. I sanded it around the
area to put some bite in the plastic, put JB WaterWeld on it, let it set, never leaked again...
Traded it in 6-months later, still wasn't leaking...
08'MustangDude is offline
Old 02-18-2019, 07:21 PM
Scott40talbot
Thanks, thatís the answer I wanted. Sand it and seal it.
Saving miney!!
setx69fastback
12-09-2009 12:57 AM
CyprusMustang
04-05-2009 12:36 PM
JayBanion
03-14-2009 03:04 PM
DonA
07-09-2007 11:27 PM
03nittostang
19
03-20-2006 05:11 PM
Quick Reply: Radiator with a slow leak - Repair or Replace?
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
