Turned key off, engine still running
And by 'running' I don't mean dieseling or misfiring, I mean running perfectly normally as though I had not just turned the key off and pulled it out of the ignition.
Disconnecting the ignition (I) wire from the solenoid stops the engine. If I reconnect the wire to the solenoid, it cranks right up as expected but it still won't turn off with the key. What's your diagnosis gang? thanks |
I did a little more troubleshooting during lunch today and discovered a couple other pieces of information.
hopefully that's enough to give you guys the clues you need |
No ideas? Visiting my old man this week though ((electrical engineer) so he's going to try to find a schematic so he can maybe figure out what might be the culprit...any ideas to help us narrow it down?
Replace the ignition switch. I just recently had the same issue with my 1966 convertible. Bought a new ignition switch, installed it and that solved the problem.
