wheel sizes
Old Jan 13, 2006 | 12:55 AM
redstallion's Avatar
redstallion
Default RE: wheel sizes
225/60-15 looks pretty good on our cars.....that's what i'm running and after i rolled the front lips there are no rubbing issues
Old Jan 13, 2006 | 01:09 AM
Markstang1969's Avatar
Markstang1969
ORIGINAL: Gun Jam
I have heard that with tight suspension stiff sidewalls will cause a decrease in handling.
It makes sense too, with more flexible sidewalls the wheel is able to shift without distorting the griping surface because the sidewall flex will allow it, thus adsorbing some sway energy.
With ridged sidewalls much less sway can be adsorbed and therefore the energy is transferred directly to the griping surface.
This was what I was told and it seems logical.
Gun
Actually, shorter sidewells allow less flex between the rim and the contact patch of the tire, allowing a more consistant grip, Less flopping of the tire (thus leading the tire to ride on it's edge) with less side to side lateral movement. Of course a shorter tire is less "forgiving" in your "azz" since there is less "mattress" between your car and the road.
Here is a quick google I am editing in:
http://auto.howstuffworks.com/framed...understand.asp
http://auto.howstuffworks.com/tire2.htm
http://www.kaltire.com/retail/custom...lus_sizing.php
Ask yourself this:
When you see a ferrari or a corvette do they have tall tires or short tires?
Old Jan 13, 2006 | 02:29 PM
Gun Jam's Avatar
Gun Jam
alright ill check it out
thanks
Gun
Old Jan 13, 2006 | 07:07 PM
speedjunkie's Avatar
speedjunkie
not only that, my 17s look bad with the disk brakes showing thru.
Old Jan 13, 2006 | 10:16 PM
Soaring's Avatar
Soaring
I ♥ Acer
I have always wonderded why the mystique of having your disk brakes showing through is so prevalent and in vogue. Guys even paint them bright red or orange in order to see them. Sounds like rice to me. [:'(]
Old Jan 13, 2006 | 10:39 PM
Markstang1969
ORIGINAL: Soaring
It's kind of like rice trying to be more like "risotto"
Old Jan 13, 2006 | 10:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, I guess those Ferrari guys can get away with it because those disk brakes cost about a zillion dollars, but I still think it is dumb to draw the attention of your car to the dang brakes, and not the rest of the body. I guess I couldn't own a Ferrari, not only because I can't afford one, but I would definitely paint those disks black.
Tivo304
Aug 28, 2023 12:19 PM
Nov 10, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 06:25 PM
Sep 3, 2015 07:14 PM
