200CI TO 289
#31
RE: 200CI TO 289
actually i have seen a beefed up I6. if u go to streetfire.net look up 66 mustang. their is a I6 that has been fitted with the turbo.....pretty sweet actually
ah heck ill just throw a link up
http://videos.streetfire.net/search/...9950584517.htm
#32
RE: 200CI TO 289
ORIGINAL: grruminator78
well you'll have to get a front sump pan, and a few other changeovers, like i think a different water pump. CHP has balanced and blueprinted shortblocks with any stroker combo you want already installed check out coasthigh.com when you get a chance, that's who I'm going with, they also make turnkeys. other places you may want to check out is mustangengines.com
Thanks for the links! I will check this out.
Thanks again!
#33
RE: 200CI TO 289
well with the serpentine kit I think you need what a reverse flow water pump not sure what all the FRPP turn key motors come with. but I think last time i checked summit and FRPP web pages it lists the stuff you have to use to use it in a classic.
#34
RE: 200CI TO 289
thanks for that link... apparently with a turbo you can get into the 13's with a 6.... makes me wanna build one =)
can a 300 be crammed into the older stangs or is it just too big?
