Sponsored by:
Sponsored by:
2000 GT CONV FRAME WON'T CLOSE ALL THE WAY
Old 05-31-2017, 05:19 AM
golfhead
golfhead's Avatar
Default 2000 GT CONV FRAME WON'T CLOSE ALL THE WAY
Towards the end of last year my wife told me that something was wrong bc windows won't close correctly against the convert top. Basically she only drove it on sunny days then we put it away for the winter and figured I would deal with it later. Finally now dealing with it and the issue is that you have to force it into the latch position and the frame is buckled. When you close it the top falls a couple inches short of closing and then when you force it closed it buckles. I figured the top had shrunk so I would replace it. I have the old top off(so now just the frame) and still doing the same thing. I unhooked hydraulic cylinders to see if they were restricting but didn't help. Need Some Help Please.......
golfhead is offline
Old 06-02-2017, 12:13 AM
jimkaray
jimkaray's Avatar
I'm a newb when it comes to convertibles so I can't offer any experienced help. I did just replace my first top and there were a lot more places to lube than I expected, even the ribs across the top rotate on heim type joints. Since your top is off I would lube and look closely for any joint that is frozen or binding up while some one else operates the top. Good Luck!
jimkaray is offline
Old 06-02-2017, 04:08 PM
golfhead
golfhead's Avatar
I will do that. Thank you jimkaray for your input!
golfhead is offline
Old 06-05-2017, 01:50 PM
golfhead
golfhead's Avatar
Default Pics added
I added some pics of how the frame is not going forward enough. It falls about 1" to 1-1/2" short. I see no issue where it hinges or anything bent?????? It was working fine until towards the end of last summer.
Attached Thumbnails 2000 GT CONV FRAME WON'T CLOSE ALL THE WAY-img_3822.jpg   2000 GT CONV FRAME WON'T CLOSE ALL THE WAY-img_3823.jpg
golfhead is offline
Old 06-16-2017, 07:41 PM
scan1959
scan1959's Avatar
There is definitely something broken on the frame or linkage.
That second bow is supposed to be about 4" or 5" higher on the top frame.
Take it to an auto upholstery shop and let them look it over. Many times it is free. That is the type of place that regularly works on convertibles. They are specialists.
Scan
scan1959 is offline
Old 06-18-2017, 10:39 PM
golfhead
golfhead's Avatar
Thank You SCAN1959. I will find someone local and have them look at it.
golfhead is offline
Old 08-14-2017, 08:48 AM
Wutang
Wutang's Avatar
Hey golfhead, did you ever solve your issue? I think I have the same problem but my account permissions do not allow me to view your images. If you did solve your problem lmk and how! Thanks.
Wutang is offline
