Ordered Tire & Rims from Cruzin Concept
Well got my rims and tires yesterday. Let me tell you the want was well worth it! The are perfect. They came in, boxed with several layers of cardboard on each side and wrapped in plastic. Not even a fingerprint on them. Tires all had exactly 32psi in them. All i had to do was bolt them up with the new lug nuts they sent for free. And I didn't even have to resync the TPMS. Work right out of the box. Cruzin Concept is the place to buy! David you are the salesmen I will come back too! And Mike, I don't know you. But keep up the good work on the boards.
As soon as I get a pic uploaded , I will post.
Everyone that see it has great thing to say about it. Everytime I pull into a parking lot someone always comes up and want to talk about it. My wife loves it but she gets made as I can't just walk away.
Thinking that now I need to lower it a bit. Not slam it on the ground but just enough that it looks good. I can do it myself. Price is an issue as I'm broke from the wheels right now. Thinking maybe an 1" or 1" 1/2" on the back and less on the front. So what would you recommend?
Thanks, Mike.
It sounds like your thinking along the lines of what I would do as well. If you keep the drop modest this will also allow you to keep your factory struts and the ride quality will remain somewhat fair. However that being said though it will effect your ride quality some as I'm sure the 20's already have to a certain degree but it won't be dramatic.
Many of the guys here are running Eibach pro-kit springs. These will on average drop the vehicle 1.3 - 1.5". Eibach for example makes a more aggressive spring with their sportline series but this is a 2" drop and generally speaking its best to upgrade shocks and struts to match the more progressive spring rate found on these. Something like the sportline as well will dramatically effect the ride quality but at the same token some folks like that as it will kinda feel like and indycar in comparison to the factory suspension setup. Anyway Ford makes a good spring which we don't carry and Eibach makes the pro-kit and there are other good springs out there as well but I think you'll be satisfied with the drop range you mentioned. You can check ours out if you like in our Mustang Lowering Springs section.
Sincerely,
Mike
Toll Free: 888-630-0655
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
