Cleaning interior gunk, dirt, crud, etc...
Welcome to my adventure in freshining up a 145K mile '96 GT for our daughter's first car...
The steering wheel is gray and there is blackish crud (hand oils + dirt) in all the various pebble/leather grain crevices. What cleaning product should I use to scrub that crud out?
I've read not to use heavy detergent cleaners. What will work without further harming the 12yr old surface?
Also, it looks like the gray color is rubbing off in areas of the center area (horse). Can I repaint that gray? Should I just replace the entire thing with a black steering wheel?
Also, is there something I can use to remove the scuffing on the door panels down by the speakers? And finally, what carpet cleaner is most effective at stain removal?
Thanks guys (and gals?)
for the scuffs and crud use some simple green and a old tooth brush. It will all come out. I would actually go over every inch of the interior plastics with the simple green. Its very echo friendly and wont further damage anything in your car.
Depending on exactly how bad the carpet is, I would suggest going to your grocery store and renting a "RUG DOCTOR" and doing the carpet right. It will cost you 14-20 bucks a day for the rental.
Its going to take some time, but in the long run you will be very happy with the results.
simple green is good. Good for the environment too. Don't bother painting the steering wheel. It will just rub off quickly. Spend $10and get a steering wheel cover. These carpet cleaning products work well (I think Simple Green does carpets too if I'm not mistaken). and elbow grease.Good luck.
Simple Green and a brush worked WONDERS on the interior - panels, carpet, everything. But it did leave the surfaces feeling vary "bare". We wiped everything down w/ armor all for now - will get something better soon - thanks for the feedback everyone...
i like the maguires line of detailing products. Unless armor all has changed over the past few years i had always heard that armor all was very bad for interior...that it speeds up the cracking process. Anyone else heard this?
