- 390 Bellhousing
- new rear end gear
- 351c compression prob
- High dollar fastback
- I have decided to get Cragar Wheels, got a question...
- The best Ford Small Block engine
- 3 or 4 row radiator?
- EFI 351 in a 65 - Hood Clearance ??
- Coil and wiring replacement
- Restoring a 66 Coupe. Go with original colors or change.
- Radiator- how full?
- HiPo Exhaust Manifold vs Headers on 289
- trailer hitch
- Ask.com information site
- Ford rebuilt power steering pump came today!
- Classic Mustang store in Houston?
- 1964 1/2 Interior Color
- engine swap question
- most cost effective way to beef a 289?
- maintance work today
- Driveshaft length
- Found a Boss 302 Block wondering if I can just drop this in my stang? Casting number question also.
- the 60s difference between mustang GT
- Scratches on Piston Skirts
- Mustang vs. Integra
- water pump question?
- 2 barrel vs 4 barrel on a 289
- SOMEONE HELP! WHAT THE HECK DID I GET!!
- 2002 rear end, front brakes into 1966
- New Speedo cable not working
- 14" stocks in southern california
- 302 Engine numbers?
- 302 vs. 351 for street legal or close amateur drag car
- Grant wheel install with electrical probs? Fixed it..I think
- Over heating on Highway Solved
- carb issues?
- Found another one, trying to figure out is this is a good deal
- HEI DISTRIBUTOR QUESTION
- transmission not working after storage
- Early Hi-Po Exhaust Manifold Performance
- Fuel Gauge help
- expensive stang
- ignition switch delemma
- Introduction, and some advice needed
- Someone On Here....
- well i just got my first mustang!
- '66 Fastback
- I'm loosing my mind
- Anyone Want A Cat?
- Sun Tach
- Rear End Confusion
- On the Spike PowerBlock today (5/20)
- American Graffiti Salute
- Complete Wire Replacement.
- 67 convertible whats it worth
- 8000 rpm rally pac tach
- 67 front wheel bearings relacement
- 66 power steering to rack and pinion conversion help
- power windows
- rear disc brakes
- steering rack, info needed
- My favorite GT Clone
- GT trumpets done!
- Rebuilt Engine Back In
- Door water shed paper replacement
- Ignition problem...REALLY weird...
- Car Show Pics
- ball joint remover needed?
- Power steering pump
- 92 block...now what?
- ENGINE DECODER
- studders almost staills then jerks forward
- RUST!!!!
- Body work done! Paint next weekend.
- How much would you pay for this?
- Automatic transmission cooler lines revisited
- Bench Seat / 4 Speed
- Question about cost for a 289
- Dual Vacuum Advance Problem - Hesitation?
- Speedo Gear question
- Is Changing The Ignition A Major Thing To Do?
- Cleaning Convertible Top???
- Finally got on the road!
- Off to Kruse auction tomorrow
- Shelby Spring Fling Nashville IN 5/19-5/21
- timing shoots up to 30 degrees.
- 67 6 cyl wheel bearings
- Tire size calculator link for you guys.
- '66 Stock 289 correct point gap
- 1985 302?
- 302 Upgrades
- original 1965 GT-350
- Instrument cluster question
- Well guys I belive I'm done with that website design.
- 428CJ vs 427 & Suspension Advice
- disc conversion
- How tall are you?
- How much wider would a 275x40 be???
- Help, Clutch Problems!
- 170ci's?
- Relaying the problem...
- The little engine size emblem on the front fenders
- It's the transmission mount
- Fog Light Bulbs..
- Radiator water/coolant question
- To use or not to use?
- quick oppinion question
- Need help beefing up a staight six
- In the Midst of My Rebuild, Take a Look
- axle suggestions
- added power disc
- 1965 9" rearend in a 1967
- Help Radio Brackets dash area
- long time no see
- Easter color??
- starting issue on a 1968 I-6
- Reverse vibration issue re-visited
- Headlight Pull Switch
- Ford lawsuits against companies using Mustang in their name
- Header question!
- What Tach ya'll sportin?
- MOVED: timing chain.
- wheels test fit!!
- Quick Help...proper placement for hog nose rings?
- I6 ignition prob.
- This looks like a good buy...
- classic pricing help
- SS wheels - argent to dk charcoal?
- Cylinder Heads
- rally pack clock
- side scoops?
- 1968 GT
- How do I remove my third member?
- 1970 Mustang Audio
- Is synthetic oil ok for an ol' 289 motor?
- License plate
- 66 heating/cooling system
- My radio works
- Vacuum secondary adjustment
- Flasher Location on 67
- Don't shoot me soaring...I'm posting a want ad
- water leaking problems
- old engine brace after the new export brace
- What's it worth??
- Is it possible...?
- 69 A/c Dash Vent
- Craigslist find!
- a great score!
- Wiring a 302
- I opened a can of worms
- What do I need to install kickdown cable?
- Good Deal or Not??
- Rear End Rebuild, what gears?
- Where to buy Fuel Tank?
- Rear spring are done!!
- Wiring Diagram
- Anyones else have problems with WhitePost Restorations?
- Auto to Manual Swap
- Frame Rails What to do?
- Rear end...to buy or not to buy?
- fuel pump
- underride traction bar pics
- Casting number
- Droppin the gas tank
- Classic Song
- 66 Wiring questions
- 351c4v ?
- Still looking for the best Dash Pad
- Concept
- bumber tuck ? 73 mach1
- 66 Engine resoration questions
- Side lights on my 68
- finally got a classic mustang...frame rail questions
- fastbacks that great???
- Schematic for 1968
- Radiator Leakeage
- Granda disc vs Mustang disc
- Ahhhhhhh!
- '66 Repaint
- Carburetor?
- I built a mustang fish tank.
- 1968 Mustang badges
- widest tire in the back?
- Got my Granada swap on!
- Update on work progress.
- Looking for the guy with the cool Ignition wire looms
- Fuel Gauge Wiring
- MPG and HP
- How much Horsepower...
- What's your favorite wheel?
- RPM >high< acceleration >low<
- noisey power steering
- missing on 1 cylinder
- PLEASE Help - Power steering just not right on my 65 Fastback
- Heater Hoses - plugs?
- 347 vs 351W
- Cleveland heads??
- 67 Carb Problem 2v help?
- 67 289 Exhaust Header Problems
- Distributor: Points vs. No Points
- Which Fuel Pump for a 289 with a 4Barrel?
- Advanced Timing and Starter Overheating
- FE or sb
- So my car magically works?
- Fuel Problems
- Need pics of Shelby wheel 56, 66 & 67
- boss 302 4v heads
- Suggestions on my trunk?
- Gummy silicone?
- 65 CUSTOM RADIATOR AND ELECTRIC FAN
- need help with door tag info
- here she is
- Photo albums
- Ever melt jumper cables?
- Help with Flat Spot
- Home made Ram Air. Whacha think?
- 200ci I6 intake problems
- Identifying camshaft
- You guys should check this out
- Draining Battery
- Well that Scamer sent me an Email today...
- Toploader shifter knob thread size?
- 67/68 front end measurement
- need a place to work on pony
- add a pic how?
- Suspension upgrade question on a 67
- t5 into 64-5 falcon/comet
- Conv 1968
- Hertz Paint Code
- '66 Fastback
- Brake parts help
- ignition system
- Is Seattle a bad place to buy?
- 67 -68?
- Steering Shaft Repair
- need info on installing headunit/speakers for '67 coupe
- 67 coupe for sale
- 68-73 dust/splash shields
- 289 DISTRIBUTOR, what would you get?
- what a rear end mess
- Mig welding help. Problem w/soleniod power
- smoke @ 75mph
- steering wheel removal
- Steering question
- Header question on 70 Mach
- Rear shock is in the way.
