Radiator Overflows over 50mph
New Radiator, pump, and thermostat. The cap is old. It was fine yesterday, its not overheating. It just spits fluid out of the overflow tank when I go over 50. Whats wrong?
ORIGINAL: 68Midnight
When your engine is cold, the overflow tank should only be about 1/4 full. If you are belching water out the top of the recovery bottle, you have too much water in it. Yeah, and change that old cap out to a new 13 pound one.
I was thinking that. Also the lower rad. hose also isnt in the best shape, and it might have a slight sharp angle when it turns into the pump...
i'd flush it, get new hoses and a new cap, remember to let it burp real good and get all the air out. i like to let mine run a good 5 to 10 minutes, filling as it burps (CAREFULLY, we already had one member get burned yesterday!)
fill the rad, start the car, leave the rad cap off, CAREFULLY watch the bubbles come out of the system.
it removes the air trapped after the coolant gets drained, hence burping.
you'll prolly need to let it run for a few to get it all out
Here ya go......
http://www.ehow.com/how_7369_burp-cars-cooling.html
you should change your SN to GlenTheLinkKing
