Carburetor Gasket
Old Jan 22, 2007 | 08:51 PM
rlbjrcpa's Avatar
rlbjrcpa
Default Carburetor Gasket
When I pulled my carb there was one between the spacer and carb, but not intake and the spacer.
Shouldn't there be two gaskets? One between theintake manifold and carb spacer and a second between the spacer and the carb. Thanks.
Old Jan 22, 2007 | 08:53 PM
atomsk680's Avatar
atomsk680
Default RE: Carburetor Gasket
not needed
Old Jan 22, 2007 | 09:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
There should be one between the spacer and the carb, but not between the spacer and the intake manifold. Actually, you don't need any gaskets at all. I used to run with a spacer that I cut from a piece of 3/4" outdoor plywood without any gaskets and it ran just fine.
Old Jan 22, 2007 | 09:05 PM
my77stang's Avatar
my77stang
well plywood is soft so it would seal, i would think a gasket is in order anywhere two metal surfaces meet to ensure proper seal
Old Jan 22, 2007 | 09:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
That's true if the surfaces are not perfectly flat. The phenolic spacer is perfectly flat.
Old Jan 22, 2007 | 09:11 PM
atomsk680's Avatar
atomsk680
ORIGINAL: Soaring
o i didnt know that, i had gaskets on both between my spacer and intake and between my spacer and carb, and when i bought new spacer it had both gaskets
Old Jan 22, 2007 | 09:12 PM
rlbjrcpa's Avatar
rlbjrcpa
Thanks guys - didn't see any evidence of leaks, but I'll add the gasket when I rebuild just to be safe.
Old Jan 22, 2007 | 09:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, the paper gaskets don't take up any space and may fill in a lonely little space that was created at the factory so you may as well use them if you have them. They are generally not necessary though.
Old Jan 23, 2007 | 12:30 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I run a gasket between the intake and spacer, and between the spacer and carb.
Oct 26, 2015 05:01 PM
Dathan
Oct 5, 2015 05:52 AM
wraith777
Sep 28, 2015 10:49 AM
Demodulates
Sep 18, 2015 11:14 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
