Ran out of Toe In adjustment - Suggestions?
Old Jan 25, 2007 | 11:12 PM
68SCode4speed's Avatar
68SCode4speed
Default Ran out of Toe In adjustment - Suggestions?
After rebuilding the rear suspension, front suspension, steering components, converted to a Granada disc brake kit, added Rosehill strut rods, BaerTracker bump steer kit - the only thing left to do is install the dual master brake cylinder, all in one distribution/proportioning valve. The s/s brake lines are installed, now I just have to figure out how to get the spaghetti mess in the engine compartment neatly arranged.
I have one big concern right now though – the toe in/out adjustment that can be made on the Baer tracker bump steer kit has run out of toe in adjustment. I have it cranked all the way to its shortest setting but eyeballing it very closely on both sides it looks like it still needs more toe in - justa hair more. I'd like to have more available just because I don't want to be up against the stops when it is in correct alignment.Here are some suggestions as to correcting the problem:
1.) Shorter tie rods that the threading goes farther up the rod
2.) Cut of ¼” on each side of the center adjustment tube
3.) Thin the lock nuts that lock tight against the center adjustment tube
The car is a '65 Mustang and somewhere I remember reading that this might be a problem on 65/66 Mustangs but the writer thought that it wouldn't be... whoops...
Old Jan 25, 2007 | 11:17 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Ran out of Toe In adjustment - Suggestions?
Cut the adjuster.
Old Jan 26, 2007 | 01:24 AM
JamesW's Avatar
JamesW
Door #2....
Old Jan 26, 2007 | 01:57 AM
68SCode4speed
Thanks guys - just got an e-mailresponse back from Day at Daze Cars and he said the same thing. Major thanks for the help! Now I know when I am cutting a little bit off the adjuster that I don't have to wince & worry while doing so...
This website rocks!
Lethaldosage423
Oct 19, 2015 12:12 AM
69Volunteer
Sep 30, 2015 10:39 AM
MustangV6P
Sep 28, 2015 11:00 PM
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
