hood alignment
working on my '65 hood alignment. Old hood fit fine in the back by the cowl. Front damage dictated a new hood. New hood doesn't fit at the cowl. It rides high. I have the hinges down all the way. When the hood is closed, I can press down and get the hood to match the cowl. I am thinking weak springs. Anyone had experience with this?
marty
marty
I do not think the springs affect this. It is a common problem. IIRC the solution is to loosen the hinge bolts at the firewall. Then push up on the hood. Tighten the bolts and check the hood for alignment. Repeat as needed. I'm going off of memory of something I read on one of these forumns. A search may be in order.
ORIGINAL: highhilleer
So you open the hood, loosen the firewall bolts, then push teh hood towards the sky and tighten the bolts? Will this somehow lower the hood? Right now, my left hood rides about half an inch too high compared to teh fender. I'd think I'd need to push down and tighten...
I had a set of old hood hinges that acted a lot like that. I found three of the hinge pins to be worn allowing movement, which translates into a lot with the hood. Wouldn't close all the way, but could be pushed in place once it was down.I replaced these with a new set only to find out that it made it worse. After checking the new set, I found they had more slop in them than my old ones did. Every pin had movement (like a 1/4" pin in a 3/8 hole). What junk.I then repaired the old originals but haven't had a chance to change them, but am sure it will fix the problem.
ORIGINAL: Guitylerham
lol so yeah, i've spent alot of time adjusting hoods.
Report due by tomorrow....
