will newer rims fit?
i really dont much about rims and tires... so if i get some of the stock rims and tires that come from the new gt models they'll fit? where do i get the spacer and how will it work?
if you use the 01-04 bullits you will need a 1 inch adapter in the front and a 1/2 spacer in the rear. if you do the 05-08 bullits you will need 1.1/2 inch adapter int ehfront and 1 inch in the rear
heel chart that was put together by dodgestang is amazing and will help you out...
http://www.dodgestang.com/cgi-bin/pr...ts%201965-1973
go to the wheel chart section and look in awe!
