Which gauges should I go with?
Old May 7, 2008 | 09:13 AM
nassaubayman's Avatar
nassaubayman
Default Which gauges should I go with?
I'm upgrading to the deluxe (aluminum) dash inserts. While I'm replacing the bezel, I want to install some Autometer gauges. Right now, I'm leaning toward the Carbon Fiber gauges. However, the Sport Comp, with the black face, look more like the original equipment. Plus, the Sport Comp gauges are about $170 cheaper. I'm not as much of a fan of the white-faced Phantoms, but I know a lot of people are, so I included them in the poll. They're also priced about the same as the Sport Comps. Finally, there's the Ultra Lites. The grey gauge under the aluminum bezel looks pretty cool. But they're about the same price as the Carbon Fibers, which I like better.
The cheapest site I've found to buy Autometer gauges is www.egauges.com. Does anyone know of some place cheaper to buy them?
I've been to the Classic Instruments site. I don't think I like their gauges as much. Is there another brand I should consider?
Carbon Fiber
Sport Comp
Phantom
Ultra Lite
Old May 7, 2008 | 11:59 AM
66JameStang's Avatar
66JameStang
Default RE: Which gauges should I go with?
LOve the Phantoms and carbon fiber.... I would say go dakota digital
Old May 7, 2008 | 01:20 PM
RGMotorsports's Avatar
RGMotorsports
I say ultra lite, but you do know that classic instruments will build you any gauge with any face you like, they will even put classic mustang font faces on autometer gauges.
Old May 7, 2008 | 01:42 PM
nassaubayman
Classic Instruments wants $1150 for theirs. And thats for a black bezel. If you want the aluminum bezel, you have to buy one and send it to them (I called & spoke to someone about it).
JME Enterprises offer both the black and deluxe bezels. Their prices start at $1099.95.
I'll take a stab at building my own and save some bucks.
Old May 7, 2008 | 01:50 PM
68EFIvert's Avatar
68EFIvert
I went with Sport Comps in my camera case bezel. I like them because they get attention but don't scream look at me like some of you other choices. I like the carbon fiber gauges, just not sure it they would look at home in a classic. Let me know if you need any pictures of mine. I would be happy to post one.
Darreld
Old May 7, 2008 | 02:15 PM
nassaubayman
Pictures would be wonderful.
Also, I came across this tutorial
http://www.edbert.net/gauges.htm
Did you cut the rings off yours like this guy did? Did you cut up your backing plate like he did? I'm getting a gauge support from Mustangs Unlimited that's supposed to hold Auto Meter gauges, so I'm hoping I won't have to deal with the backing plate issue.
Any other words of wisdom?
Old May 7, 2008 | 04:13 PM
68EFIvert's Avatar
68EFIvert
I think I am the one who posted that link on your other post last week. I did do the exact same thing and chose to cut the original gauge support. I did that because I think the gauge support is also used as a ground for the gauges. I was some detailed instructions over on Vintage Mustang Forums where a guy used the gauge support you purchased but then had to cut the top portion of his gauge support so that he could screw it to the dash and provide a ground.
It was not difficult to trim the backing plate. I used an air body saw that I picked up at harbor freight for less than $20. That saw, a screwdriver, an angle grinder and some wiring tools is all you need. I will snap a picture of the back of the gauge cluster as well. My wiring is not as clean as others may be but it works and I will never see it.
The cutting of the backing plate took about 30 minutes (at the most). The trimming of the bezel was about the same amount of time. After doing the mod once I think I could get the whole project done in 4 hours. That includes the time it takes to wire the gauges. Just have a wiring diagram handy before you start and label all the wires as you remove them from the original cluster.
Good luck and I will post the pics after I get the kids in bed later tonight
Old May 7, 2008 | 09:48 PM
68EFIvert's Avatar
68EFIvert
Old May 7, 2008 | 09:52 PM
EmperorOfChicken's Avatar
EmperorOfChicken
you should get DeFis!!...oh god ive been hangin around my import friends too much, just kiddin man. sport/pro comp is the way to go.
Old May 8, 2008 | 08:46 AM
nassaubayman
Your three small gauges - are they 2 1/16" or 2 5/8"?
