New (to me) roof
I finally picked up a donor roof for my 65 today. I plan to drill the spot welds around the windows and I see the seam on the front pillars so I will seperate there but trying to decide where to cut it on the back pillars. right now the donor goes all the way down to the bottom of the rain gutters. I plan to dispose of my gutters anyway. What are your opinions for where to stop it around the back window. Any other helpful suggestions would be appreciated as well.
[IMG]local://upfiles/64293/01946440A27947C89FE71ADBFE0FBC63.jpg[/IMG]
id take it at the factory seams, also keep in mind if you delete the drip rails your gonna need to weld that seam up since thats where the inner and out roof are joined together
I knew that I was going to have to weld up that seam. I think that I will cut out my old roof and install it on the donor supports to get a feel for what I will have to do to get it to look the best before welding the new skin on my car. How is the inner cross member attached to the roof skin. It looks like glue. What is the best way to seperate the two without warping my new skin? Do you think I will have to put in any bracing to avoid body flex or should there be enough support with the inner framework?
Well I have alredy replaced the drivers side rear quarter, Outer wheel well and the trunk area to the gas tank. Floor pans filled in my cowl vents and made about a dozen patch panels for rusted out areas around the car. I still have to replace the passenger side pillar and the rear taillight panel. I will take pics of the roof fabrication. I wish I would have taken more pics of other projects and I lost some that I did take when my computer crashed.
I might take you up on that Darreld. I dont know if I will try to tackle it this week end with mothers day here. But maybe next weekend. I am going to try to reprime the engine bay this weekend for the final blocking. with luck I can cut up the donor during the week after work.
