rearaxle 9" housing to 3rd member. gasket or gasketmaker
Hi all,
I received a housing and 3rd member, but forgot to order the gasket.
I've rear that they tend to leak anyways, so it's better to use a product like 'gasketmaker'.
Any opinions on this, or products I should be looking for?
Ford here gets scared when I mention classic mustang. They have no clue and are afraid selling wrong part.
So instead of ordering a gasket from states, I'd love to know if there's an alternative
thanks a million
Kalli
thanks a million
Kalli
i allways use a good silicone one from you parts store should do the trick just make sure its clean i just put a thin coat on let set 4or 5 min and then bolt in 3rd member
good luck
good luck
asked Brydon, who sold it to me and he recommends the silicon as well. So I'll go with that.
Just to let you all know. It might depend from application to application, so I'll go with what the seller suggests.
Thanks rmodel65 and quesey for your opinions!
Kalli
Kalli
thx Tad,
seller says he didn't sent gasket as he recommends RTV only. I would put in a gasket and RTV as you suggest, but that would involve ordering and waiting for 1-2 weeks, that I don't want to wait.
If I go to a car part store, they don't know what to give me if the car is older than 5 years and Ford here doesn't have any expertise on that whatsoever as well. So unless anyone says the 2008 Ford Transit has the same gasket I won't be able to source one here
Make sure the surfaces are clean before the RTV. I usually tighten the bolts just snug, then let it set overnight, and finish tightening them down the next AM. No leaks so far.
I always use ultra black RTV on mine. a thin amount on each side and put them together with no gasket. Aftermarket rearends are much stronger than the original 8 and 9's so they don't flex and cause leaks.
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
stangin1996gt
Sep 21, 2015 11:01 AM
