Subframe Connector?
Old Oct 29, 2009 | 01:05 PM
Piraya33's Avatar
Piraya33
Default Subframe Connector?
1) Is there any preferred brand out there?
2) How much should a shop charge me to weld in a set of subframe connectors?
Old Oct 29, 2009 | 01:17 PM
racin66coupe's Avatar
racin66coupe
1. TIN MAN.
2. better not be much. i would think around 100 if not less
Old Oct 29, 2009 | 01:18 PM
racin66coupe
http://www.tinmanfabrication.com/ind...prod/prd58.htm
$145 is pretty expensive but VERY nice product
Old Oct 29, 2009 | 01:38 PM
palerider's Avatar
palerider
+1 On tinman. Put on my 70 Mach - nice fit. Welded up myself. Was pretty easy. Muffler shop should be able to do in 1 hour.
Old Oct 29, 2009 | 02:12 PM
Adrenolin's Avatar
Adrenolin
Yup.. I've got the Tin Man Fabrication ones on our 67 and its makes a world of difference! Easy install and (depending on) the shop should be able to do it for 1 to 2 hours labor.
Old Oct 29, 2009 | 02:42 PM
cprstreetmachines's Avatar
cprstreetmachines
DAMN, you guys are fast. I usually use TCP. And it takes 3-4 hrs. They wrap around the frame rails up front and lay flat against inner frame rails in the rear. But take a good bit of massaging to fit the usually. Especially to lay flat on the back rails.
But the best is use the floor. TIME consuming, but worth the extra effort.
Old Oct 29, 2009 | 04:02 PM
JamesW's Avatar
JamesW
I used the TinMan also and it took the muffler ship less than an hour to install them. I think it cost me about fifty bucks.
http://www.midnightdsigns.com/Mustang/subframe.html
Old Oct 29, 2009 | 05:37 PM
cprstreetmachines
Just looked at the tinman...they only have two mounting points ?!
Old Oct 29, 2009 | 07:34 PM
Piraya33's Avatar
Piraya33
Did you use a chain store or a small local shop? Is a muffler shop the best place to take it? Thanks!
Old Oct 29, 2009 | 08:01 PM
Adrenolin's Avatar
Adrenolin
They get welded at various points in the front rails since they slide right up inside them a fair distance. I think I had 8 spot welds inside and outside the front rails as well as along the joint. Also they get a fair bit or solid welding on the rear rails. Once installed the difference in the cars stiffness was incredible.
