Lincoln LSC disc brake rear axle
Old Oct 30, 2009 | 03:58 AM
super64's Avatar
super64
Default Lincoln LSC disc brake rear axle
Hi Guys,
A friend of mine has a Lincoln LSC rear axle sitting out in front of his garage. Although it's been exposed to the elements for a while, it is complete from rotor to rotor. He got it for his '40 Ford panel truck, but he's going to use something else.
He has offered it to me for $450.00. Does anyone here know any of the particulars on this rear end? I haven't measured it yet, but does anyone know (off the bat) if this axle could be used on my 64 1/2? Or, should I get a disc brake kit for what is more than likely an 8" rear that is already in my car?
Thanks in Advance,
Brian
Old Oct 30, 2009 | 04:16 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
450$my goodness im assuming this is the solid rear axle from a Mark 7 not the Mark 8 correct??
the Mark7 uses an 8.8 rear just like the 5.0 mustangs but is even wider by .75 incs on each side iirc the stock mustang rear is too wide
Old Oct 30, 2009 | 04:45 AM
super64's Avatar
super64
Thanks for your Reply. Yes , it's solid. Did the Mk VIII have IRS? Is $450.00 a good deal?
Old Oct 30, 2009 | 10:27 AM
jcoby's Avatar
jcoby
no, it's a horrible deal. go get an explorer 8.8 with discs and a 31-spline posi for around $200 and cut down one side if you want an 8.8.
Old Oct 30, 2009 | 12:05 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i paid 150 for an 8.8 drum rear with 410s.... and that was kind high but it had gears already
Old Oct 30, 2009 | 02:53 PM
super64's Avatar
super64
Hi Guys,
Thanks so much!
Brian
Nov 10, 2015 11:39 AM
musnicki
Sep 23, 2015 07:11 AM
Dragonus18
Sep 9, 2015 01:21 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 3, 2015 07:14 PM
