Why do i get this ? Everytime i reply to a message? I DONT HAVE AOL
We are sorry...
You are seeing this message because we are experiencing problems with serving pages through the AOL browser.
Solution #1:
If you are an AOL User, Please try the following...
Click START, then CONTROL PANEL (or settings, then control panel), click NETWORK AND INTERNET CONNECTIONS, then INTERNET OPTIONS.
Under the GENERAL tab:
In the Temporary Internet Files Area -
#1. Click the Delete Cookies button
#2. Click the Delete Files (make sure to check the delete OFFLINE CONTENT) button
In the History Area -
#3. Click the CLEAR HISTORY button
AOL USERS >>>>>>>>>>>
Click the EDIT menu from the top of the screen (above the mail box and write mail icons).
Select CLEAR TOOLBAR HISTORY.
Click YES To Erase The History.
Restart your computer
Then try logging into DF and posting. If it works GREAT! Let me know. If not, take the four steps again, then RESTART the computer and try.
Please bear with us. This problem WILL clear out in time, but this could help it move out faster.
Solution #2:
If you are an AOL User, Please try one of the following steps...
Right Click on AOL Icon (not on your desktop, the SMALL icon next to the time on the bottom right)
System Info
Cleared Cache
Utilities, Clear Browser Cache
Re-Built Aol Adapter
Restart
Either JavaScript and/or Cookies are Not Enabled on Your Browser.
You enter the forum with an URL that contains invalid Session ID.
Problem #1:
To use our forum (ASPPlayground.NET Forum SQL), JavaScript and Cookies must be enabled.
Netscape Communicator 4+:
Select "Edit" from the browser Menu bar
Select "Preferences"
Double click on "Advanced"
Verify that "Enable JavaScript" is selected
Verify that "Accept only cookies that get sent back to the originating server" is selected
Select the "OK" button
Microsoft Internet Explorer 4+:
Select "View" from the browser Menu bar
Select "Internet Options"
Select "Security" tab
Select "Custom (for expert users)" security level and select the "Settings" button
Locate "Scripting" and verify that "Active Scripting" is enabled
Locate "Cookies" and verify that "Allow per-session cookies (not stored)" is enabled
Select the "OK" button on the "Security" window
Select the "OK" button on the "Internet Options" window
Once you have enabled both JavaScript and Cookies you may try the forum again.
Problem #2:
You have bookmarked a page that contains your previous (invalid) Session ID. Always bookmark our forum's home page WITHOUT the Session ID. e.g.:
https://mustangforums.com/?cookieCheck=XXX will be invalid the next time you enter the forum.
https://mustangforums.com/ is the page you want to bookmark.
Try again?
Technical Information
For more information, please contact forum admin.
For forum software inquiry, please contact info@aspplayground.net or visit ASPPlayground.NET.
Solution #1:
Solution #2:
System Info
Cleared Cache
Restart
Problem #1:
Problem #2:
Try again?
JoshyGT
09-19-2017 08:52 PM
