Redass (moderator in off topic) is completely out of control
#34
#35
MK2, your post looks to be nothing more than a childish attempt to try to get a mod removed. Off topic is a fairly rough section, and redass acts accordingly to keep the section running as smoothly as it does.
If you have an issue with a moderator, making threatening "call out post" isnt going to help your cause any. In looking through your thread history, I see instances where youve posted something that has been removed, so you then either reposted or made a thread complaining about it being removed.
Off topic is a "privilage" area...and if you dont like how it is run, ive solved the problem for you. Calling out a moderator on this forum is grounds for being banned, but if you like you can remain a member here, but keep in mind that you are a GUEST here, and that the rules and moderators are to be followed.
Thank you, and have a lovely day.
jwog666
12-27-2021 08:09 PM
