10" to 10.5" clutch
10" to 10.5" clutch
I have clutch questions for a 86 GT 5.0 T-5. Can someone please tell me what is involved in going from a 10" clutch to a 10.5" clutch? I know I need a different flywheel, but will a bigger flywheel also mean a bigger bell housing, different starter gear, different anything? I thought all 86 5.0s had 10.5" clutches, but when I pulled mine today I found out it is a 10". Someone please help me.
RE: 10" to 10.5" clutch
all you really need is a new pressure plate and clutch disk, im pretty sure. i havent read or heard anything about having to get a new bellhousing or flywheel unless you are switchin trannys. if im wrong, correct me...
The difference in the flywheel is in the surface where the plate rides but the flywheel itself is the same size. So you will not need to replace starter or bellhousing but like hotrod said you will have to replace the flywheel pressure plate and discs. As far as what came stock in an 86 Im not sure. I took my tranny out of a 93 cobra.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
