Mod response
What part of an engine determines how responsive cars are to mods. Like why do little engines like turbos, or why huge LS/LT1's take to cams and spray so well. Why arent the 3.8 and 4.6 engines as responsive.
RE: Mod response
It's not a case of "responsiveness" nor a single "part of an engine"; it's the inherent design characteristics of an engine that make or break it. The LS1 was designed with heads designed to flow better than anything GM had previously designed. I think the engineers at GM would have put in a bigger cam(that would have made much more power) if it would have been emmisions compliant and\or still maintained bottom end torque(remember; they are for sale to the masses & not specifically to drag racers). I don't know where your comming from on the 4.6's; the 4.6 mod motors respond fantastically to forced induction if you have the P.I. heads that I believe were used from 99-up.
The earlier 4.6 heads wern't designed very well; it's as simple as that. All engine's are basically air pumps. The more air, the more fuel, the more power. Of course the smaller engines get nowhere near the "tech" in thier developement since the engineers whom designed them wern't told to make 'em "hipo'. Most likely, the engineers were instructed to "Make it small, get good gas mileage, cheaper to make, etc" .....IMHO |
RE: Mod response
So bigger engines should take to bolt on mods and cams better
RE: Mod response
No not really, it's just that a bigger engine has the potental to move more air, but big engines also respond well to FI. As the poster above said, you need to look at the engine as a whole system, but heads are really the part that can make the biggest differance.
RE: Mod response
So the design of the heads is what determines how well the engine takes to mods
RE: Mod response
ORIGINAL: ByPopularDemand So the design of the heads is what determines how well the engine takes to mods |
RE: Mod response
Whoops.... double post....Sorry..... |
