What motor would you pick to run High 10's low 11's? - MustangForums.com
Old 05-03-2006, 02:04 AM   #1
KKell83
Default What motor would you pick to run High 10's low 11's?
If you had a goal for high 10's low 11's (or 550rwhp) what engine would you start off with. Smog doesn't mean a thing. Any engine would be blessed with boost or nitrous.
a 306/331/347 5.0 with all the goodies
a 351w/396w/408w 5.8 with all the goodies
a 4.6 sohc (stock heads)
a 4.6 dohc (stock heads & cams)
The reason I ask this dumb question is because I gave up my quest for a Cobra mustang (96-98) for an older 60' coupe. I found one in mint condition for a reasonible price plus I'll still have upwards of $5-6 thousand to do anything with.. I would rather build a FI engine instead of a CARB. to be different and have the "OH ****!" factor. This isnt going to be a month project, closer to a year if that if the car works out. But since I dont have the car now I'm not going to mention any more of my dreams just yet.
I know there isnt anything called a CHEAP race car, but what if you had a choice to choose your next build.. What would it be? I know if I pick anything above it would work no matter what. But what would be easier to work on, OEM & AM parts, cheaper (As in buying heads for a 5.0 compaired to keeping the stock 4.6 heads, that saves 1k right there) In my mind right now I'm thinking about a sohc motor since you could find then easier then a dohc, plus they could make good power like anything else...
Okay guys what would you pick... Sorry for such a newb. post but I'll like some opinions. Kenneth.
KKell83 is offline   Reply With Quote
Old 05-03-2006, 10:43 AM   #2
R1PPED
Default RE: What motor would you pick to run High 10's low 11's?
there is a post here about nice engines. its pretty recent.
https://mustangforums.com/m_1194654/tm.htm
Check that out. The company sells a 427 capable of 550 hp on pump gas. It around 6,000 dollars. Cheap as hell for that power.
From what I hear the company who builds the engine is very reputable.
good Luck with your search
Chris
R1PPED is offline   Reply With Quote
Old 05-03-2006, 11:07 AM   #3
randy78045
Quote:
ORIGINAL: R1PPED
Chris
I would stay away from a 427... A 408 w/ a 200 shot of gas is the ticket for the times you seek... but its all gonna cost you more than 5 or 6K... an remember suspension, etc...
randy78045 is offline   Reply With Quote
Old 05-03-2006, 11:16 AM   #4
grabbem88
hell you can get mid 10's with a heads up 408...juice for 9's
grabbem88 is offline   Reply With Quote
Old 05-03-2006, 11:22 AM   #5
randy78045
Quote:
ORIGINAL: grabbem88
Ya if you can hook up... have a little problem there...
Old 05-03-2006, 11:30 AM   #6
grabbem88
well if you can hook up.....
Quote:
ORIGINAL: randy78045
Quote:
ORIGINAL: grabbem88
Old 05-03-2006, 02:28 PM   #7
R1PPED
Randy, how much did your engine set up cost you and was it a crate engine or custom build??
Chris
Old 05-04-2006, 01:09 AM   #8
waxyourboard
http://www.mustangandfords.com/techa..._428_windsors/
There's an article about the 427W vs the 428 FE
With edelbrock heads and a cam, both of them put out over 500 hp (if you slap a roller cam in there... which it comes with, so no biggie)
Throw a 100 shot on there, or you could even boost it if you want, and you got yourself a 550 horse+ (to the wheels) machine.
waxyourboard is offline   Reply With Quote
Old 05-04-2006, 01:20 AM   #9
Zoie_daGT
I would go 408 for the HUGE displacement or the 4.6 DOHC because it is a great engine. I kinda like the 408 better esp. in an older car.
Zoie_daGT is offline   Reply With Quote
Old 05-04-2006, 07:13 AM   #10
hookandpull
def a 408 stroker
hookandpull is offline   Reply With Quote
Did a few mods this summer... drfister 2005-2014 Mustangs 11 05-03-2018 10:38 PM
Shift Linkage Broke, Could Really Use Some Help CMcNam 4.6L V8 Technical Discussions 15 12-06-2015 01:28 PM
2002 Mustang GT 4.6L engine and manual transmission Gary Ugarek Parts For Sale 1 09-05-2015 09:03 PM
timing issue 1987gt40ttopt 5.0L (1979-1995) Mustang 12 08-28-2015 10:49 PM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 12:59 PM
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
