Anyone have any ideas? I just installed a Vortech on my 95' and everything is kosher except the cooling fan isn't kicking on. The thermostat is obviously working, as I get good temp reading at the stock water temp guage, however it just keeps getting hotter without the fan kicking on, I have to run the AC to mandate that the fan operates. Could I have damaged the fan relay when I took it out? Any sensors I should check? Thanks in advance.
You can test the sensor with an ohmmeter. If you check it when the engine is cold. You should read around 74 ohms. If engine is hot (full operating temp) it should be around 9.7 ohms.
