i just ordered a MGW shifter will i need any manual transmission fluid?
Old 05-10-2006, 10:49 PM
Vash the Stampede
Vash the Stampede's Avatar
Default i just ordered a MGW shifter will i need any manual transmission fluid?
Will i need any manual transmission oil to lube anything? will i need to lube the shifter at all before sticking it in? also will i need to add any additional manual transmission fluid in?
Vash the Stampede is offline
Old 05-10-2006, 10:50 PM
sprostang
I ♥ Acer
sprostang's Avatar
Default RE: i just ordered a MGW shifter will i need any manual transmission fluid?
No.
sprostang is offline
Old 05-10-2006, 10:58 PM
jlong00
jlong00's Avatar
No fluid needed - you will however want to put either a gasket in, or a bead of sealant on the bottom of the shifter plate.
Btw, CONGRATS!
jlong00 is offline
Old 05-10-2006, 10:59 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Congrats on the new order!! You won't be disappointed. Where did you order from and what shift ball did you get?
PRO50SC is offline
Old 05-10-2006, 11:12 PM
Vash the Stampede
just a shifter and a gasket. iam afraid i was going to drop gasket maker all inside the transmission so i went ahead and spent the extra money for a gasket.
i got it from matt like you guys recommended me. over at http://www.stangmods.com
it costs like 10 bux more but it comes with a free gasket.. which is worth like 10bux anyways. so i went ahead and ordered it threw http://www.stangmods.com
i didn't get a new shift ball.. haha i kinda want this one if it wasn't 60 dollars for it http://www.mgwltd.com/mustang_race_knob.shtml
Old 05-10-2006, 11:19 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
http://www.mgwltd.com/mustang_gripper_shift_knob.shtml
I got the pony one. Are you just reusing your old ball?
PRO50SC is offline
myshifter
I ♥ Acer
myshifter's Avatar
No comment on the shifter ****
myshifter is offline
Old 05-11-2006, 12:18 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: myshifter.com
OK
PRO50SC is offline
Old 05-11-2006, 12:21 AM
Vash the Stampede
ya iam reusing the old shifter ****. is it going to work out?
Old 05-11-2006, 12:36 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: Vash the Stampede
As long as it's the same thread size.
PRO50SC is offline
Quick Reply: i just ordered a MGW shifter will i need any manual transmission fluid?
