How can I improve the brakes on my 04 GT?
Old 04-27-2004, 07:39 PM
propellerhead
propellerhead's Avatar
Default How can I improve the brakes on my 04 GT?
The brake pedal force needed on my 04 GT is a bit more than I would like. I know it's a matter of getting used to, but compared to other vehicles I've had, this one takes a lot more pedal force.
Are there low-cost ways of improving the brakes? Or will it take a $1,000 upgrade?
propellerhead is offline
Old 04-27-2004, 08:40 PM
MelloYello
MelloYello's Avatar
Default RE: How can I improve the brakes on my 04 GT?
Well your best bet..... Going with a high performance break assembly...
But the force and length of the peddle needed to be pushed in shouldnt really be a concern if you stop right?
If there going all the way to the floor then there is a problem....
MelloYello is offline
Old 04-27-2004, 10:50 PM
propellerhead
Yes, the car stops fine and stopping is not a concern. I just enjoy the ease and comfort of a soft touch brake pedal.
Like you said, these forums are for sharing information. so I thougt I'd ask.
Old 04-27-2004, 11:29 PM
MelloYello
MelloYello's Avatar
ORIGINAL: propellerhead
Of course
I think though if you were too tighten up slack the brakes would not stop as hard might cause problems with master cylinder
Old 04-28-2004, 08:57 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
My brake pedal doesn't need to be depressed very much. Try having the system bled, you can create a harder/softer pedal, slightly..by doing this.
Dan04COBRA is offline
Old 04-28-2004, 09:58 AM
propellerhead
Just by bleeding the brakes? Tell me why. I wanna learn!
Old 04-28-2004, 02:59 PM
roundman
roundman's Avatar
with it being so new, I would take it right to the dealer where you bought it and have them check it over thoroughly to make sure the brakes are properly adjusted and the brake booster is working correctly. do you have 4 wheel disc brakes or drums in the rear? with rear drums, they could be too tight causing a stiff pedal that don't take much movement to apply the brakes. could also be the parking brake cable needs adjustment, if too tight it will be trying to apply the rear brakes all the time and this makes for a quick pedal too.
How hard is it to pull up on the parking brake? if it don't come up much, then it might be too tight. don't think bleeding the brakes should change the pedal feel at all unless you leave some air in the lines which is not good at all.
roundman is offline
Old 04-28-2004, 05:12 PM
propellerhead
I have 4 disc brakes on this car. The parking brake works normal.
My 94 Explorer had the same thing. It took more pedal force to apply the brakes. It wasn't an issue of whether it would stop the truck or not. It stops. No question about it. It just took more pedal force. That's all.
I think I'll see about test driving similar 04 Mustangs on the lot to see if they feel different. I was just wondering if there was something simple like turning an adjustment screw somewhere.
Thanks.
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: How can I improve the brakes on my 04 GT?
