Hemi
Old May 13, 2004 | 09:07 PM
Monch's Avatar
Monch
Default Hemi
didn't know where to post this, but is the current chrysler "hemi" a real hemi or is it just marketing hype?
Old May 13, 2004 | 11:21 PM
VertStangGT86's Avatar
VertStangGT86
Default RE: Hemi
It's a hemi in the sense that it has the hemi head design but it is not the 426 hemi that made the name famous. I believe it is a 351, they're putting out about 350hp. So a little bit of a scam.
Old May 14, 2004 | 12:00 AM
04ShakinSteed's Avatar
04ShakinSteed
I ♥ Acer
Default RE: Hemi
I disagree...I dunno how many hemispherical engines they made but there were quite a few. It is a modern design of a age old classic.
Sad to say that the old one would smoke the new one...they should've made it more powerful.
Old May 14, 2004 | 12:07 AM
04ShakinSteed
I ♥ Acer
Default RE: Hemi
FYI....
The OLD Hemi's are...
331, 354, 392, and 426
The NEW Hemi's are...
426, 472, and the 528
The HP on the newer ones are...
426 - 465 HP 486 FT/LBS Torque
472 - 525 HP 540 FT/LBS Torque
528 - 610 HP 650 FT/LBS Torque
Then there are two 500 Wedge Engines...
505 HP - 590 FT/LBS Torque
575 HP - 625 FT/LBS Torque
The Big Blocks...
361, 383, 400, 413, 440
The Small Blocks...
273, 318, 340, and 360
The Magnum Engines...
4.7L, 5.2L and 5.9L
6 Cylinders...
2.5L, 3.0L, 3.2L, 3.3L, 3.5L, 3.7L, 3.9L
4 Cylinders...
2.0L, 2.2L, 2.2 Turbo, 2.5L, 2.5 Turbo
Old May 14, 2004 | 04:30 AM
USAMuscle's Avatar
USAMuscle
Default RE: Hemi
ORIGINAL: 03BlackSteed
Why is that sad?? It's awesome! You can't beat 60's muscle because emissions wasn't an issue back then, so fire-breathing big blocks came in almost everything. Granted Dodge could have easily made that kind of power with a non-hemi engine, but more than anything it is just a sales gimmick because people attribute "hemi" with incredible power and awe. It's more about bragging rights than anything. It doesn't matter what they put into it though, because nothing will top the original...
Old May 14, 2004 | 01:23 PM
VertStangGT86
Default RE: Hemi
The new ones are not a 426 unless they really messed up cause it's only putting out 350hp.
Old May 14, 2004 | 03:18 PM
Monch's Avatar
Monch
Default RE: Hemi
i think the new hemi's are 345ci, one of my buddies was going on an on about 1 hp per cube and why ford doesn't do something better with the mustangs (the same crap i'm sure all of you have heard) i had to sit and bite my lip simply because i don't know jack about the new hemi's, which is what made me ask the question in the first place.
anyway, thanks for the info...
Old May 14, 2004 | 09:26 PM
VertStangGT86
Default RE: Hemi
No, that's about the right size if not right on. It's def not a big block.
Old May 15, 2004 | 12:28 AM
04ShakinSteed
I ♥ Acer
Default RE: Hemi
ORIGINAL: Monch
You haven't seen them all yet...they don't make just one engine.
Old May 15, 2004 | 01:02 AM
VertStangGT86
Default RE: Hemi
As of right now, like what's in the durango and stuff is what I'm talking about. If they're still coming out with a big block in something that's awsome.
