Just Blew my 3rd Gear. Ouch in a 94 Gt
What do i need to do to switch out the stock trans with a tremmec 3550, pro 5.0 shifter,. And also if anyone uses that Set up how do they like it?
RE: Just Blew my 3rd Gear. Ouch in a 94 Gt
it should just swap in and out, have to use a different bellhousing than the T5, but other than that its the same. Tremmecs are the shizznit, shift great especially with a good shifter, might think about using a centerforce clutch or something equivelant though.
Going with a tremic/tko 500 Instead of the 3550 Model. getting everything i need from D&D Performance, Tremic 500 Trans,Billet steel flywheel,superduty 10.5 clutch disc,Aluminum driveshaft,Aluminum Bellhousing and a few other things $2468.00.
Here we go
Here we go
get the blowproof bellhousing i would have lost a limb without it ..pressure plate came apart...it hit so hard you can feel a ding in it on the outside ,,and you know how thick they are...if you launch at 6000 rpm plus you need one,,,i got the tko 3550.. center force warranty the pressure plate and disc,,when it failed..
[IMG]local://upfiles/5822/Ec881379682.jpg[/IMG]
jwog666
12-27-2021 08:09 PM
