98 GT Fuel Filter change - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > General Tech
Reload this Page >
Old 07-27-2006, 02:11 AM
Tsaleen17
Default 98 GT Fuel Filter change
Ok guys,
Just tried to change the damn thing and couldn't get the fuel lines off of the filter after removing the steel spring clips. Is there a spring inside the coupling that needs to be expanded so the line slides off the filter?
Also, was trying to change filter due to car bogging between 1K-2500 RPM. Was running great, gassed car up at Chevron, then started having a bogging problem. Doesn't do it when the car is cold,just when it reaches normal temp. I did notice a smell from the car the day it started acting up. Like the car smelled hot, but the temp was ok. People have suggested the IAC valve, also the 02 sensors...... Car has 92K miles on it. Just changed the intake manifold due to leaking. Car was running great for about 300 miles, then started acting up as I described.
Any advise would be much appreciated.
Tsaleen17 is offline
Old 07-27-2006, 08:08 AM
02StanGT
Default RE: 98 GT Fuel Filter change
Yes, you need a special tool. It can be had from Auto Zone. I would recommend the one that also has sizes for A/C lines, that way you don't have to buy another one. I'm not sure bout your other problem though.
02StanGT is offline
Old 07-28-2006, 02:33 AM
Tsaleen17
Thanks for the info.
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 04:09 PM
whatsup62
10-16-2015 04:07 PM
raleigh05GTO
09-04-2015 08:09 AM
5.0 kevo
09-03-2015 07:24 PM
SYNY5TER
09-02-2015 02:35 AM
Quick Reply: 98 GT Fuel Filter change
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
