is it bad for ur AOD tranny? - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > General Tech
Reload this Page >
Old 08-10-2006, 05:14 PM
live4motocross11
Default is it bad for ur AOD tranny?
I have a 94 mustang gt with the aod and i never have because im afraid to, but can u shift manuly like the 1-2 2-D or is that bad on ur tranny? how about if u let off the gas when u do it? im really just wondering so any info helps thanks a lot
cory
live4motocross11 is offline
Old 08-10-2006, 05:37 PM
samseed101
Default RE: is it bad for ur AOD tranny?
Yes you can do it. And it can be helpful at times when you want to control your shift points. I don't see a reason to come off the gas when you do it though. I just put 3.73 hears and a shift kit in my 95 GT and it makes a world of difference.
Matter of fact, I just purchased this right here:
(Edit: when I say I "just purchased it", I mean like 15 minutes ago, LoL)
http://www.hopupracing.com/bmfomucoha.html
It's purpose is to allow you to shift 1 - 2 - 3 in an AOD / AODE transmission. It's ratchet style, meaning you don thave to worry about accidentally skipping over a gear like you do with the stock shifter. You just slam it forward and it steps up one gear then recenters itself. The next time you slam it forward, it shifts up one more gear.
samseed101 is offline
Old 08-10-2006, 05:38 PM
sweet99
ORIGINAL: live4motocross11I have a 94 mustang gt with the aod and i never have because im afraid to, but can u shift manuly like the 1-2 2-D or is that bad on ur tranny? how about if u let off the gas when u do it? im really just wondering so any info helps thanks a lotcory
You can shifyt an automatic manuallly if you want and often will get better times due to firmer shifts but try shiftiing a little befoire you actually want it to shift as it may take a couple hundred rpm's to react. Not sure about the letting off of the throttle thing, what you mean. mark
sweet99 is offline
Old 08-10-2006, 06:21 PM
live4motocross11
^^ i meant let up off the gas then shift then get back on it if that helps? well thats cool to no that u can do that i was always told its bad for ur tranny and will grind gears or somthing
Old 08-10-2006, 07:19 PM
sweet99
Why let off the throttle to shift? Just shift it manually with the throttle to the floor and keep gonig! Mark
sweet99 is offline
Old 08-10-2006, 07:30 PM
live4motocross11
k cool i guess its not bad like i thought it was
Old 08-10-2006, 09:38 PM
Anthonyandmarisol
i have a 98 gt with aod and i do all the time but make sure you turn off the over drive and you get more torque
Anthonyandmarisol is offline
Old 08-10-2006, 09:47 PM
mustangman02232
mustangman02232's Avatar
ORIGINAL: sweet99
do this and you should cut the 1-2 shift loose, or atleast my 6er does
and no it wont, not sure on the aod but i know the 4R70 has a 1 and 2 manual valve body straight from ford
mustangman02232 is offline
Old 08-10-2006, 09:51 PM
hotrod7687
Shifting your trans like that should be fine, and theres no need to let off the gas before you shift.
What you want to be careful about is downshifting an auto, especially when you're not on the gas. If you downshift into a gear too low or arent on the gas when you shift it is very hard on the trans. I destroyed a chevy turbo 350 doing that
hotrod7687 is offline
Old 08-11-2006, 01:34 AM
live4motocross11
k thanks guys, i tried it and its pretty cool, more fun than just an auto i guess
Quick Reply: is it bad for ur AOD tranny?
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
