Want to cut my eibach sportlines.
Ok guys who has experience cutting these things? where should i cut them? top or bottom? and does any one have a picture of the exactly location of where i should cut them?
just as the title says, i want to cut my springs but i dont know which one to cut. should i cut the stockers or the eibach sportlines?
and more importantly where should i cut them? does anyone have any experience with cutting springs?
AND PLEASE JUST DONT come in this thread telling me NOT to cut them, because i want people with actual experience with cutting springs.
i know for sure these cars had their front springs cut iam not sure where.
but this guy told me that his is dropzones that has been cut and isolators tossed, but he doesn't know from which end because he bought the car and it was already like that:
and this one has also had this springs cut. but he traded in his car for an STI and i can no longer find him to ask him which end he cut his Steeda Comp springs.
RE: Want to cut my eibach sportlines.
I would advise against cutting them, if you want it a little lower remove the isolators. However if you HAVE to cut them i'd say cut them at the bottom, and cut in small intervals...
ORIGINAL: OnyxCobra
The reason i say the bottom is becuase the top is flat, the last coil flattens out so it seats at the top. The bottom is a loose coil and you'd be able to rotate the spring without affecting how the top sits. I actually dont see how you could cut the top of the spring...
Edit: after doing some thinking, since the top coils are "dead coils" it might make sense to cut them becuase then it would not affect the ride quality of the spring... Or you could sell your Sportlines and get some H&R SuperSports [sm=icon_rock.gif]
Also because of the difference in the two springs (i assume the sportlines are a variable rate spring?) in terms of ride quality you will have much better luck cutting the stock springs.
Is there a reason why you want to cut them? Why not just take out the isolators?
[IMG]local://upfiles/25112/51E9A6F5DE4C4722897401E4E96362F0.jpg[/IMG]
Why don't you just buy new springs and not ruin the way the car handles. Honestly springs are not that much and why take the chance of having a car that drives like crap.
ORIGINAL: JD1969
i just want the front droped..... iam thinking about a coilover kit. its only 150-200 dollar kit.
I am pretty sure if you want to go lower than the sportlines you will be looking at a race spring of some kind, I am not really a lowered car kind of guy so I am not up on all different kits out there, I do know that cutting springs is never a good way to lower the car though. Coil overs are an option as well.
