oil pressure looks low???
finely drove my car today,,5 miles temp was running about 180/190 ..oil pressure after it got hot was just 15psi, at 1000 rpms,,,,brand new motor 408,,i got a hi vol. oil pump,,running 5x30 wt reg oil for break in,,but at 2000 rpms hot was at 55 psi, .....i think i will just run thicker oil next time........how low is your oil pressure????? i got a mech., gauge...$hit![&o]
RE: oil pressure looks low???
need people with mech gauges to replie!!!!!!!!!!!!!,,,going to change oil again ,,i change it 2 times back to back ,,,after builing motors,,i like to be safe ,,theres lots of $hit that can ruin your motor so oil is cheap,,i change after each outing to the track...
oil pressure seems just a tad low 20 psi is about right...I would drop in some 10w30 reg oil and drive to easy for alil while...did you gauge the space for the pickup to pan area...see what the new oil does and get a good oil filter..like k/n or amsoil/hastings..does this engine have a solid or hyd cam?
ORIGINAL: vfast
