5.0 cooling plate - throttle body
Question - what purpose does the "cooling plate" on the throttle body serve? i had a hard time finding the gasket( i was leaking a/f into my intake)... so I just bypassed the cooling plate with a new hose...
impacts?
impacts?
RE: 5.0 cooling plate - throttle body
it warms air for cold morning so to speak...all I usr is a 6" of coppertubing and by pass it buy then you check engine light should come on,next take out the sensor leave it connected and put alum. foil around the exposed sensor and but a plug at lower for the hole and the check engine light will go out
ORIGINAL: stjh1029
thanks.. yes, now that you mention it, the egr mounts to it as well....
hey where exactly is the sensor i'm trying to wrap foil around? which one?
Luke9222
10-22-2015 11:55 PM
