Rounded off brake line fittings - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > General Tech
Reload this Page >
Old 10-24-2006, 09:10 PM
C!ph3r
Default Rounded off brake line fittings
Oh boy. Here is what’s happened. I am converting am 87 2.3 into a 5.0. I am in the process of changing the suspension and brakes. I am trying to remove the soft brake hose going to the caliper and have manage to round of the fitting that attaches the hard line to the soft line.
1: How do i get this fitting out? I have sprayed WD40 and Brake Clean like crazy and cannot seem to get it to come free.
2: Can i cut the line off right up against the fitting, flare it and put a new end on it. If i do this, will the hard line then be to short to reach the new steal braided line?
Also, is there a special type of wrench i should be using to remove these fittings with out damaging them or am i going to just have to deal with it for the fact the car is almost 20 years old? If that’s the case i guess i better buy enough tubing and fittings for the other side and the rear also.
Thanks gang.
C!ph3r is offline
Old 10-24-2006, 09:44 PM
Tac2cul
Default RE: Rounded off brake line fittings
im not sure ont he length issue
but u could reflare it and put a new end on it and be good
u need a special wrench called a "Line Wrench" in order to not stripe those
but since u have already messed this one up id say get some vise grips and have your way
Tac2cul is offline
Old 10-24-2006, 10:06 PM
C!ph3r
a line wrench. is that the same as a flare nut wrench. of coarse. that would make since. i tried the vice grips and no luck. i guess i'll just cut it.
thanks for the info.
C!ph3r is offline
Old 10-24-2006, 10:27 PM
Tac2cul
yup same name for the wrench
good luck man
Tac2cul is offline
Old 10-25-2006, 12:13 AM
C!ph3r
cool thanks. i'll post how it goes
C!ph3r is offline
Old 10-27-2006, 02:31 AM
C!ph3r
Well, looks like i am just going to replace the line from the mc to the passenger side. i cut the end and attempted to make a new line with a fitting. well it ended up costing me more for the tools to make the double flare then just buying a new line. off to 50resto i go. thanks for the help. this has been a learning experience for sure.
C!ph3r is offline
Old 10-27-2006, 05:46 AM
Tac2cul
damn man dat sucks
hope it all works out for ya
Tac2cul is offline
Tivo304
05-30-2018 05:58 PM
10-07-2015 08:02 PM
musnicki
09-23-2015 08:11 AM
mtgldr
09-10-2015 10:43 PM
Quick Reply: Rounded off brake line fittings
Featured Sponsors
