MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   General Tech (https://mustangforums.com/forum/general-tech-6/)
-   -   swapping headlights on 94-98's (https://mustangforums.com/forum/general-tech/202656-swapping-headlights-on-94-98s.html)
hookedonkronik Nov 7, 2006 11:48 AM
Is this an easy task? I figure it wouldnt be too hard to do and really dont feel like paying someone a bunch of money to install if its pretty easy. I should let you know im not experienced too much when it comes to cars so it will definitely be a learning experience for myself.
I figure so many have done this that I should get a fairly detailed reply on how to do it.
Thanks all
Kadence Nov 7, 2006 12:13 PM
RE: swapping headlights on 94-98's
It fairly easy but it is very easy to break the clips that hold it in place, so be careful
onegreedy Nov 7, 2006 01:49 PM
There are no screws on the headlights , just 2 plastic clips and they are really tough, i just used the wood end of the hammer and pressed them in and they poped right out , (do inner first then outer )
as for corners there is 1 10 mm nut on the corners and then they jsut work out , reverse install and your done, took me 30 minutes to swap out from stock to projectors
wmustanggt Nov 8, 2006 07:59 PM
This is a fairley easy task just look on the new head lights on the back and you will see where u need to look on your headlights in your car to take take off stuff and put on stuff!
© 2026 MH Sub I, LLC dba Internet Brands
