Installing new exhaust manifold
RE: Installing new exhaust manifold
ceized manifold bolt . YOu could break the hea doff and leave teh rest of the bolt in the head but take you time let the car run for a while to let it get hot them spray teh bolt down with rust penitrator while te manifold is still hot and they should come back out. Work each bolt back and forth as you take the out so you dotn mess teh threads up
kool like i said let it run for a while, the heat will free up the bolts and spray them with pb while its running and goodd n' hot. work the bolts in and out as u remove them dont try to remove them in a hurry or they are destin to break
Good luck let us know how u make out
Well, everything went pretty good on getting the manifold out. But, when my brother went to remove the rail from the old manifold he accidential broke it. So, we just left it off. The car seems to run just fine without it.
