Help With Wiring Fog Lights plz....
... Okay, I just bought some after market fog lights made by Pilot... I've got everything down accepted the simple wiring scheme.... I don't know where or how to install one of the wires to a Switched Power Sorce... it's a 2001 3.8 Mustang... someone hlep please... this is my first time ever doing this and much help would be appreciated... thanks...
RE: Help With Wiring Fog Lights plz....
I am assuming your are not replacing the stock lights. So for a new installation, you will need to run a ground for the lights, then run the hot lead into the interior. Check the firewall and find the opening that the main harness goes through. Use something to gently thread the wire through, and then take it to a switch. The switch will have two prongs, one for the load, the one from the lights, and then run a wire from the other prong to a switched source in your fuse panel. Not sure of the location of the fuse panel on the 01. Take your time. Good luck.
jaiidutch
09-14-2015 10:29 AM
