How hars is it to pull an intake manifold?
RE: How hars is it to pull an intake manifold?
not very difficult...i would get a haynes repair manual from auto zone etc if you feel unsure. it will come in handy over the years anyway. also put this in the 4.6 section where they'll know more about your POS plastic manifold. i heard they crack very often
Well, I started by taking the alternator off so that I could stick my hand toward the bypass hose under the manifold. It turns out the leak is not A/F but oil most likely from the head [&:]
It may be seepage that pools in the valey between the two heads.....
I did not continue to remove the manifold since that will probably have nothing to do with oil
panic
09-10-2015 05:56 PM
