trouble shifting into 1st gear.
im having trouble shifting into pretty much any gear, but first is the hardest. when the car is off i don't have a problem. it's not the clutch, cuz i just had that replaced with the entire clutch kit, flywheel pp, t.o. bearing. can anyone lead me int he right direction?
RE: trouble shifting into 1st gear.
syncro issues may be the culprit too, t5's are pieces of ****. You may need to rebuild the actual tranny, I would check the clutch first too, what actually happens when u try to. of course it grinds, but does it seem like once u try puttin it in the second time the grinding is much less and it just slips in, or do you have slight intermittent issues with 2nd gear also, if so, i would check your tranny.
jwog666
12-27-2021 08:09 PM
