Fuel Pressure??
Old 01-08-2007, 08:14 PM
ho85GT
ho85GT's Avatar
Default Fuel Pressure??
I just tested my fuel pressure becuase i have some hard starting issues... the psi's r a constant 39-40,but after i switch the key off the pressure drops immediately to 0psi w/ a matter of seconds....
Im pretty sure that the fuel system should hold some pressure after the pump is switched off. right? if im right, im thinking that the FPR is bad what do you all think? this is for my pretty much stock 95 cobra.
thanks,
Brandon
ho85GT is offline
Old 01-08-2007, 10:01 PM
P.S.I.cho
P.S.I.cho's Avatar
Default RE: Fuel Pressure??
yes the system is supposed to hold risidual pressure, you could have a bad pressure regulator thats not closing all the way allowing fuel to flow back to the tank, or a leaky fuel injector soaking the pistons when your turn the key off, you can do fuel pressure drop test, but it requires the trigger that u hook up to each injector and record pressure drops to find wich injector may be sticking open or closed. what was the initial problem that made you want to test the fuel pressure?
P.S.I.cho is offline
Old 01-08-2007, 11:39 PM
ho85GT
ho85GT's Avatar
Well i hate having to pretty much prime my engine before starting which is like key on crank, crank..wait a sec crank,vroom. as well it seems to stumble once it finally kicks in and starts to stop.
Could the problem also be related to a check valve in the fuel pump...suggested on another forum
ho85GT is offline
Old 01-09-2007, 08:51 PM
P.S.I.cho
P.S.I.cho's Avatar
ya it could be that too i didnt think about it untill u said somethin
GimpyHSHS
19
12-19-2023 01:12 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel Pressure??
