max compression for 93 octane
2 questions- anyone know the max compression i could in my 351W with aluminum heads on 93 octane?? do you think it would be worth it to run higher compression and use octane booster??
RE: max compression for 93 octane
I don't know about on a 351 persay, but I know of several guys running upwards of 12.5:1 on their honda motors on pump gas.
anything over 13:1 would need race fuel. |
I wouldn't feel comfortable with anything more than 10.5 to 1
here in cali alls we's gets out the pump is 91 and its good for 10.5 ta 1 so ide say 93 is good for atleast 10.5.
you can build a 351 to run on somewhat high compression and pump gas, but you need the advice of a pro engine builder to pick the right combination of internal parts to make it all work correctly without fear of detonation on pump gas. I think about 10.5:1 like MD already said is about as far as you can go and be safe, but it easy to get the wrong combination, so get some pro advice. You might try talking to www.coasthigh.com or www.dssracing.com to see what they would recommend.
ORIGINAL: roundman you can build a 351 to run on somewhat high compression and pump gas, but you need the advice of a pro engine builder to pick the right combination of internal parts to make it all work correctly without fear of detonation on pump gas. I think about 10.5:1 like MD already said is about as far as you can go and be safe, but it easy to get the wrong combination, so get some pro advice. You might try talking to www.coasthigh.com or www.dssracing.com to see what they would recommend. |
well the hondas can as they have knock sensors to cut timing out of each cyl..his ford can not do this ..so the 10.0-10.5-1 would be about it..why worry about going any more?.. the lil hp you get from it with all the hassle isn't worth it
ORIGINAL: mkspeed26 ORIGINAL: roundman you can build a 351 to run on somewhat high compression and pump gas, but you need the advice of a pro engine builder to pick the right combination of internal parts to make it all work correctly without fear of detonation on pump gas. I think about 10.5:1 like MD already said is about as far as you can go and be safe, but it easy to get the wrong combination, so get some pro advice. You might try talking to www.coasthigh.com or www.dssracing.com to see what they would recommend. |
Everytime I think of Summit I think of that guy with a mullet on the toilet in front of his trailer ordering parts for his Camero... haven't seen that pic in a long time...
you asking?
YOUR SUMMIT RACING DEALER [IMG]local://upfiles/1534/714A3E33627044F69104D5629B026C87.jpg[/IMG] |
