Royal Purple or Royal Baloney
RE: Royal Purple or Royal Baloney
I use it, and you can't tell, I asked a RP rep, and he stated that there test were from an independent shop and they got 10hp but you need to replace Engine, Tranny and Rearend oils to get those numbers. I can get the same results from Mobil Oneor Amsol oils
ORIGINAL: Jay Meagher
I tried it back when I raced in the NMRA.. Many of the FS racers were using it and it did pick up 9-10whp. The problem is by the 5th pull it was back to what it made before the oil change. It was talked about as being "final round oil". I ended up using crude 5w20 with half a quart of Lucas. My engine would pick up 9whp adding the Lucas and run the same over and over. I don't know that the Lucas was helping or fixing a problem with the oil I was using. With stock lifters and high spring pressures gains would be had, on a stock engine I don't know what the outcome would be.
I wouldnt say 10 hp, maybe a couple. The biggest difference I first noticed is my exhaust note changed a little. Less load on the rotaating assy and all I guess. The engine did seen a little more responsive but nothing to indicate gains like they are saying.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
