Royal Purple or Royal Baloney
I was flipping through my Hot Rod magazine the other day and I saw an ad for Royal Purple synthetic oil that claims it can give you an additional 10 horsepower.
Is this a true fact or a complete sack of crap?
RE: Royal Purple or Royal Baloney
ORIGINAL: Li0nHart
I have heard that you can get a bit more HP from a "slicker" oil but i doubt 10HP. I think the best benifit of synthetic is the fact you can go longer between oil changes.
I tried it back when I raced in the NMRA.. Many of the FS racers were using it and it did pick up 9-10whp. The problem is by the 5th pull it was back to what it made before the oil change. It was talked about as being "final round oil". I ended up using crude 5w20 with half a quart of Lucas. My engine would pick up 9whp adding the Lucas and run the same over and over. I don't know that the Lucas was helping or fixing a problem with the oil I was using. With stock lifters and high spring pressures gains would be had, on a stock engine I don't know what the outcome would be.
