afr165's vs. stock heads
can you realy compare the two??? .....no. tore the motor apart today and took a couple of pics of the new and the old
still need some pushrods (get those tomorrow). hope to have it running tomorrow afternoon but doubt it cause im not in a huge rush
http://www.koolpages.com/potatohell/filename.html
RE: afr165's vs. stock heads
md, i took your and jdaniel's advise and just stuck the ac pump to the side. i hope to have it running monday (tomorrow) but if not, i wont be able to work on it tuesday (in school for 9 hours) so i will get it running wednesday. wednesday is payday so i wouldnt mind sense i need new o2's. in the morning the car smell like its running rich, the check engine light flickers randomly, and from 800-1100 rpms the engine bogs like its flooded. if put around 6k miles on the car sense i got it, have no idea how long theyve been on there but they look bad. once it warms up, engine is fine at all rpms, no rich smell and no check engine light so im hoping the sensors fix it.
on a side note, what oil should i use 10w-30 or 40?
lookin good. good luck on gettin her running right. and i agree w/ MD.....you cant even work over a set of E7TE heads to flow WITH the AFR's, much less flow better. AFR's are one of THE BEST aftermarket heads on the market, but, ima go with a Trickflow top end(heads, cam, manifold, etc)
